Hi
I’ve got Home Assistant Container running on a Pi behind a fixed IP address. I’m trying to get HTTPS to work for Alexa integration. I’ve got my certificate from letsencrypt and I’ve added the following lines to configuration.yaml:
# Example configuration.yaml entry for the HTTP component
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
I’ve copied fullchain.pem and privkey.pem to those folders. When I restart home assistant I get the following:
[2855329360] The system cannot restart because the configuration is not valid: Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/ssl/fullchain.pem' not a file for dictionary value @ data['http']['ssl_key']. Got '/ssl/privkey.pem'. (See /config/configuration.yaml, line 10).
[2851818488] The system cannot restart because the configuration is not valid: Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/ssl/fullchain.pem' not a file for dictionary value @ data['http']['ssl_key']. Got '/ssl/privkey.pem'. (See /config/configuration.yaml, line 10).
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1491, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1526, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 728, in admin_handler
await result
File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 161, in async_handle_core_service
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/ssl/fullchain.pem'
Any ideas why this isn’t working??
Sam
