Just wondering if anyone has encountered this issue before please.
I hit start in Letsencrypt and its logging this error:
starting version 3.2.4
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator standalone, Installer None
Obtaining a new certificate
An unexpected error occurred:
The request message was malformed :: Error creating new authz :: Invalid character in DNS name
Please see the logfiles in /var/log/letsencrypt for more details.
Performing the following challenges:
http-01 challenge for xxxxxxxxxxx.duckdns.org
Waiting for verification...
Cleaning up challenges
Failed authorization procedure. xxxxxxxxxxx.duckdns.org (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://xxxxxxxxxxxxxxx.duckdns.org/.well-known/acme-challenge/DUVkMfAX0J3_hpF0En9dOoUkgSL5zTP6iLIs_oX1K9o: Timeout
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: xxxxxxxxxxx.duckdns.org
Type: connection
Detail: Fetching
http://xxxxxxxxxxxxx.duckdns.org/.well-known/acme-challenge/DUVkMfAX0J3_hpF0En9dOoUkgSL5zTP6iLIs_oX1K9o:
Timeout
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address. Additionally, please check that
your computer has a publicly routable IP address and that no
firewalls are preventing the server from communicating with the
client. If you're using the webroot plugin, you should also verify
that you are serving files from the webroot path you provided.
I think this message has to do with the port forwarding rules on my router.
Here is the port forwarding rules setup on my router:
Should port 80 be already open on my Raspberry Pi for port forwarding to work?
If I use an open port checker, like https://www.yougetsignal.com/tools/open-ports/, port 80 is closed.
I’ve spoken to my ISP, and they assure me that they are not blocking any ports.
I personally believe its an issue with my router (Nighthawk R7000).
Is the second picture some kind of auto discovery for open ports on a specific ip? If so I wouldn’t consider it a problem that port 80 isn’t shown here. The add-on should open the ports only when needed (that is, when running the challenge).
I’d suggest you configure your router to forward external port 80 to internal port 8123 and check if you can see the hass.io login while connecting from the outside. that way you can make sure it’s not your provider’s fault.
Is your dns entry up to date (does xxxxxxxxxxx.duckdns.org point to you current ip)?
I ended up using these instructions and didn’t need to install/run letsencrypt, as duckdns takes care of everything now - And no need to open any ports! (Apart from 443 to 8123).
