Level adjustment curves for dimmers
I have multiple combinations of dimmers and LED light bulbs. With LED’s, especially, “25%” on the dimmer is already almost 100% in perceived brightness. Because of this, when using my voice assistant, I have to hunt around in a narrow range for the brightness I want:
“Alexa, set kitchen overheads to 16 percent…”
“Alexa, set kitchen overheads to 12 percent…”
“Alexa, set kitchen overheads to 14 percent…”
What would solve this is if we could have some translation curves, defined by just a handful of points, like:
transfer_curves:
  - name: wemo_led
      - for: 0
        send: 0
      - for: 50
        send: 14
      - for: 90
        send: 20
      - for: 100
        send: 100
So, if I ask for 50% brightness, HA would really send 14% to the device. If I ask for 90% brightness, HA would send 20%. Other levels would be interpolated (so, asking for 95%, half way between 90 and 100, would result in HA sending 60%, half way between 20 and 100). Also, the for 0/send 0 and for 100/send 100 could be the defaults, so those wouldn’t even be needed to be provided. For many devices, you could probably satisfactorily approximate a logarithmic taper with just one point (probably what to send for the 50% brightness).
This way, we could assign different curves to different lights and just ask for a certain level which would be consistent across all of our lights (or any variable-level device, like a motor or powered speaker).
Typically these adjustments are made on the hardware itself via it’s config. Zigbee and Zwave devices typically offer this. Outside that, you can make template lights that do exactly what you’re asking here.
Wemo also has a setting for this, and you can do it on the hardware itself.
Adjust Wemo Brightness
  1. The Wemo example uses six steps to adjust min/max brightness (pressing/holding buttons, waiting for LEDs to flash certain colors, adjusting brightnesses, etc). Furthermore, this is to set the minimum and maximum brightness levels of a dimmer. I’m not suggesting limiting the range of brightnesses (I still want it to go from super dim to 100%). I’m suggesting changing the way it progresses through those brightnesses. Sending a 1 to the dimmer gives me very dim (good). Sending a 255 to the dimmer gives me very bright (good). Sending a 127 (about 50%, numerically) gives me about 97% of perceived brightness (bad).
  2. I’ve got a pretty feature-laden dimmer (Homeseer WD100/200/300 series), and it just allows setting minimum dim levels. Even if all dimmers offered that feature, they would all have different parameter values for different dim levels… and Zwave and Zigbee devices have different ways of getting to their parameters (with Zigbee’s “cluster” system being particularly unintuitive)… not to mention the various Wifi-based interfaces.
    A unified translation function (from what the user wants to what HA needs to request) would make this: 1) more intuitive for the user, 2) uniform across devices of all systems (Zigbeen, Zwave, Hue,…), and 3) even make it available to dimmers which don’t have this built-in.
The brightness adjustment you’re proposing must be bi-directional.
If you set the light wntity to 50 and it transmits 40 to the physical device, the device will reply with an acknowledgement that it was set to 40. The received value of 40 must be translated to 50 to correspond with what was requested.
Until a volunteer developer finds the time and interest to implement this feature (and the development team accepts it), you can use the Template Light integration to create a ‘virtual light’ (for each one of your existing lights) that controls brightness according to whatever algorithm you choose (employing a template).
  • Use the set_level option to convert brightness values transmitted to the light entity representing the device.
  • Use the level_template option to convert brightness values received from the light entity representing the device.
Not a problem. You can use the interpolation in reverse, as well. But I realized it could be made even easier. You can pretty much use exponents to get a curve that rises early or late, and it’s easy to convert it back (i.e. taking the square root in one direction and squaring in the other direction).
Because we really don’t need exact values, it could just offer varying degrees of aggressiveness (in the same way that electric vehicles can offer lighter or heavier regenerative braking), and the user could then just experiment with, say, “skew darker - medium” (would send lower actual values than requested by user) or “skew darker - heavy” (would send yet lower actual values than requested by user), “skew lighter - medium” (would send higher actual values than requested). Meanwhile, asking for 0 would always send 0 and asking for 100% would always send 100%.
Here’s an example of how just taking different powers of the requested value (once you normalize it to between 0.0 and 1.0) skews how those values progress from 0.0 to 1.0:
Screenshot 2023-08-11 at 12.29.41
That’s good news because it means you’ll have no difficulty using it in a Template Light. Whatever challenges you may encounter and overcome, those tips can be passed on to whoever ultimately implements this FR.
Did you ever implement this as I also want to be able to set up level curves for dimmers so that I can use a dimmer to morph between scenes for a number secondary lights by interpolating from a set of known values which I provide? In my case I want to go even further, such that the input brightness will be used to control hue and saturation also, so that there are a number of output curves which vary as the input brightness changes.
This is the first entry that comes up on Google when searching for how to change the dimming curve in Home Assistant, and yes, using a Template Light this is possible, so if anyone is interested here is some actual code.
  1. You need to be able to edit the configuration files, so have the VSCode add-on, or the SSH add-on or something else ready that allows you to do this.
  2. Make sure you add this line to your configuration.yaml:
    light: !include lights.yaml
    (Note: light is singular at the start, plural at the end)
  3. Create a new file called lights.yaml in the same folder as configuration.yaml, with the following content. You will need to replace some values with real ones first however:
    • TECHNICAL_NAME: your entity name in technical format (lowercase only, use underscores instead of space, etc)
    • FRIENDLY_NAME: your entity’s name in nice format
    • UNIQUE_ID: a random ID. You can use any online GUID generator, and remove the hyphens
    • ENTITY_NAME: the original light that you want to change the dimming curve on
    • MINIMUM_VALUE: the minimum brightness you want to allow. This will be mapped to the 1% setting. This value is between 1-255, so if you have a percentage, multiply it by 2.55. For example if the minimum brightness you want is 15%, put 15*2.55 = 38 here
    • EXPONENT: the steepness of the dimming curve. Larger values mean slower ramp-up, so the lower percentage values will be used more tha higher this number is. Use something between 1.5 and 5, with 3 giving a fairly okay result in my opinion.
    (Make sure to replace all of the occurences in the template below, before adding it to Home Assistant’s config. Also make sure you do a case sensitive search&replace)
      lights:
        TECHNICAL_NAME:
          friendly_name: FRIENDLY_NAME
          unique_id: UNIQUE_ID
          value_template: "{{ is_state('ENTITY_NAME', 'on') }}"
          level_template: >
              min(255, max(3,
                  max(0, (
                    state_attr(
                    'ENTITY_NAME',
                    'brightness'
                    ) - MINIMUM_VALUE
                  ) / (255-MINIMUM_VALUE))
                ) ** (1 / EXPONENT)
              ) * 255
              )) | int
          turn_on:
            action: light.turn_on
              entity_id: ENTITY_NAME
          turn_off:
            action: light.turn_off
          set_level:
              brightness: >
                  min(255,
                    max(3,
                      MINIMUM_VALUE + (
                        (brightness / 255) ** EXPONENT
                      ) * (255-MINIMUM_VALUE)
                  ) | int
Here is a specific example:
  1. Updated the configuration.yaml. It now looks something like in the middle:
    script: !include scripts.yaml
    scene: !include scenes.yaml
  2. Going to change the variables with the following substitutions:
    TECHNICAL_NAME: living_room_dimmed_light
    FRIENDLY_NAME: Living Room Light
    UNIQUE_ID: 9bea201bb2014901a66de1762942d0ac
    ENTITY_NAME: light.shelly_dimmer_living_room_light_0
    MINIMUM_VALUE: 100
    EXPONENT: 3
  3. The result is the following lights.yaml file:
      lights:
        living_room_dimmed_light:
          friendly_name: Living Room Light
          unique_id: 9bea201bb2014901a66de1762942d0ac
          value_template: "{{ is_state('light.shelly_dimmer_living_room_light_0', 'on') }}"
          level_template: >
              min(255, max(3,
                  max(0, (
                    state_attr(
                    'brightness'
                    ) - 100
                  ) / (255-100))
                ) ** (1 / 3)
              ) * 255
              )) | int
          turn_on:
              entity_id: light.shelly_dimmer_living_room_light_0
          turn_off:
          set_level:
              brightness: >
                  min(255,
                    max(3,
                      100 + (
                        (brightness / 255) ** 3
                      ) * (255-100)
                  ) | int
  4. Once this is setup I can use entity light.living_room_dimmed_light to control the original light (light.shelly_dimmer_living_room_light_0 with a proper dimming curve)
If anyone else finds this and try to get it to work in 2025, here’s two things you need to know:
  • The Template API has changed. I guess the API used in the above examples will continue to work for some time, but it’s best to update it.
  • There are some errors in the formulas used in the code (a mix-up of the min and max values - the formula only works when max = 255).
  • The formula for reading the value should be corrected somehow - just multiplying with the inverse exponent does not work correctly. I’m not great with maths though, so for the time being, I just use an Exp value of 1 (i.e. a linear transformation), which works fine enough for the time being.
Here’s my personal example.
  - light:
    - name: "Tevehörnan - Taklampan"
# 61 and 102 are my Min and Max values, respectively (out of 255)
# 4 is the Exp value. The formula for reading the value should be corrected
# somehow - just multiplying with the inverse exponent does not work
# correctly. I'm not great with maths though, so for the time being, I just use an
# Exp value of 1 (i.e. a linear transformation), which works fine enough for the
# time being.
# "light.zwa61_tevehornan_taklampan" is the underlying entity to control
      turn_on:
            entity_id: "light.zwa61_tevehornan_taklampan"
      turn_off:
      level: >
          min(255, max(3,
              max(0, (
                state_attr(
                "light.zwa61_tevehornan_taklampan",
                'brightness'
                ) - 61
              ) / (102-61))
            ) ** (1 / 4)
          ) * 255
          )) | int
      set_level:
          brightness: >
              min(255,
                max(3,
                  61 + (
                    (brightness / 255) ** 4
                  ) * (102-61)
              ) | int
I put the above in a “templates.yaml” file, and have the following line in configuration.yaml:
template: !include templates.yaml
