I’m looking into buying a level lock plus. I 95% want it for the Apple Home Key capability, but would also like to bring it into HA using matter/thread.
Does anyone have experience, do you have to use an Apple TV/HomePod for the Home Key function, or can I use the HA ZBT-1?
I don’t have experience with this lock (I elected not to get it because you can’t setup guest pin codes on a schedule, you have to have them install the app and grant them access there), but I did get a Schlage Lock that has HomeKey support.
To answer your second question, yes, you need an AppleTV or HomePod to use HomeKey. For the Schlage, there is no Matter support, so I couldn’t technically get it into HA if I wanted HomeKey support. For that lock I used HA HomeBridge to share a binary sensor with the lock state between the two environments. On the HA side I made a template lock using that binary sensor. On the Apple Home Side I have some automations that change the state of the binary sensor when the lock state changes and lock/unlock the lock when the binary sensor state changes. This allows me to get state and control the locks from either platform.
