I would like to leverage the --timer-finished-command in a Wyoming Satellite to send a notification to our phones when a timer has finished. Preferably with the name of the timer in the notification.
Does anyone know how this would be accomplished?
I assume I would need a script in the Wyoming Satellite to send a webhook to Home Assistant to trigger an automation. Im just not sure how to accomplish this…
In case someone else is searching for this answer…
Create an automation triggered by a webhook first.
This is the contents of my script:
#!/bin/bash
curl -X POST -H "Content-Type: application/json" -d '{ "key": "value" }' http://192.168.86.193:8123/api/webhook/-<my webhook>
In the folder you put the script in your Wyoming Satellite, you need to run the command
chmod +x your-script.sh
This will make the script executable.
Make sure to be in the folder the script is in to run that command
Then in your wyoming services config add
--timer-finished-command '/home/your-file-path/your_script.sh' \
