I’m new to HA and have hass.io running on a raspbpi. I’ve integrated all my devices and am just starting to write my automations. However, when I call for my light switch to turn on to a set brightness, it will work correctly the first time, but it only seems to work every other time after that. The other times it will just turn on to normal brightness like if I manually turn it on at the switch. Is there something in the configuration that I have missed, or maybe a work around? I remember I had similar problems in webcore, so my work around was to call an ifttt webhook maker, because in ifttt you can call a Leviton “Activity”. I was hoping not to have to use ifttt at all though.
Bumping in the hopes of a response
