Seems like it is getting worse.
I removed it, and added it again. Unknown node. Removed, added it traditional way. Same. Removed, added as secure node. Same.
Ugh? Any ideas? How do I get it back to recognizing what kind of device it is?
I think these errors are the problem.
2019-07-29 16:19:57.218 Info, Node007, Sending (Query) message (Callback ID=0x2b, Expected Reply=0x04) - ManufacturerSpecificCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x72, 0x04, 0x25, 0x2b, 0x98
2019-07-29 16:19:57.229 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-07-29 16:19:57.229 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2019-07-29 16:19:57.246 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0x2b, 0x00, 0x00, 0x02, 0xc2
2019-07-29 16:19:57.246 Detail, Node007, ZW_SEND_DATA Request with callback ID 0x2b received (expected 0x2b)
2019-07-29 16:19:57.246 Info, Node007, Request RTT 27 Average Request RTT 33
2019-07-29 16:19:57.246 Detail, Expected callbackId was received
2019-07-29 16:20:07.221 Error, Node007, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-07-29 16:20:07.221 Detail, Node007, Removing current message
2019-07-29 16:20:07.221 Detail, Node007, Notification: Notification - TimeOut
2019-07-29 16:20:07.222 Detail, Node007, Query Stage Complete (ManufacturerSpecific1)
2019-07-29 16:20:07.222 Detail, Node007, AdvanceQueries queryPending=0 queryRetries=0 queryStage=NodeInfo live=1
2019-07-29 16:20:07.222 Detail, Node007, QueryStage_NodePlusInfo
2019-07-29 16:20:07.222 Detail, Node007, Queuing (Query) ZWavePlusInfoCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x5e, 0x01, 0x25, 0x2c, 0xb6
2019-07-29 16:20:07.222 Detail, Node007, Queuing (Query) Query Stage Complete (NodePlusInfo)
2019-07-29 16:20:07.222 Info, Node007, Sending (Query) message (Callback ID=0x2c, Expected Reply=0x04) - ZWavePlusInfoCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x5e, 0x01, 0x25, 0x2c, 0xb6
2019-07-29 16:20:07.234 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-07-29 16:20:07.234 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2019-07-29 16:20:07.251 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0x2c, 0x00, 0x00, 0x02, 0xc5
2019-07-29 16:20:07.251 Detail, Node007, ZW_SEND_DATA Request with callback ID 0x2c received (expected 0x2c)
2019-07-29 16:20:07.251 Info, Node007, Request RTT 29 Average Request RTT 31
2019-07-29 16:20:07.251 Detail, Expected callbackId was received
2019-07-29 16:20:17.223 Error, Node007, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-07-29 16:20:17.223 Detail, Node007, Removing current message
2019-07-29 16:20:17.223 Detail, Node007, Notification: Notification - TimeOut
2019-07-29 16:20:17.225 Detail, Node007, Query Stage Complete (NodePlusInfo)
2019-07-29 16:20:17.225 Detail, Node007, AdvanceQueries queryPending=0 queryRetries=0 queryStage=SecurityReport live=1
2019-07-29 16:20:17.225 Detail, Node007, QueryStage_SecurityReport
2019-07-29 16:20:17.225 Detail, Node007, QueryStage_ManufacturerSpecific2
2019-07-29 16:20:17.225 Detail, Node007, Queuing (Query) ManufacturerSpecificCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x72, 0x04, 0x25, 0x2d, 0x9e
2019-07-29 16:20:17.225 Detail, Node007, Queuing (Query) Query Stage Complete (ManufacturerSpecific2)
2019-07-29 16:20:17.225 Info, Node007, Sending (Query) message (Callback ID=0x2d, Expected Reply=0x04) - ManufacturerSpecificCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x72, 0x04, 0x25, 0x2d, 0x9e
2019-07-29 16:20:17.238 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-07-29 16:20:17.238 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2019-07-29 16:20:17.255 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0x2d, 0x00, 0x00, 0x03, 0xc5
2019-07-29 16:20:17.255 Detail, Node007, ZW_SEND_DATA Request with callback ID 0x2d received (expected 0x2d)
2019-07-29 16:20:17.255 Info, Node007, Request RTT 29 Average Request RTT 30
2019-07-29 16:20:17.255 Detail, Expected callbackId was received
2019-07-29 16:20:27.226 Error, Node007, ERROR: Dropping command, expected response not received after 1 attempt(s)
