Leviton DZ6HD state issues
Been having issues for some time with this switch. It’s the only one I have in the house and it just never wants to show the state correctly. Just now I turned it on at the paddle and left the room and wanted to turn it off but HA showed it as off. So I have to turn it on via HA and then hope that the state holds (sometimes it flicks back to off) then I can turn it off. Any suggestions? I’ve re-interviewed and that doesn’t help. Running latest version of everything.
What type of controller do you have? There are currently known firmware issues with the newer 700 Series controllers.
You mean my z-wave/ZigBee dongle? If so HUSBZB-1.
I’m seeing similar issues with them. I just added several more switches and now I notice the issue. I didn’t see it about a month ago. Right now I’m using a Aeotec Z-Stick Gen5
I’m not sure if it showed up with the new devices or upgrading zwavejs. Unfortunately I added more devices and upgraded zwavejs at the same time.
I was actually seeing this before upgrading to Z-wave JS. Just been lazy in trying to get an answer. I also think my 3 way GE non plus setup I have for hallway lights will occasionally do it but I don’t tend to use those much through HA to worry.
Personally I am running Home Assistant Container so I run the zwavejs2mqtt Docker container supplied by the developer. It uses the official zwavejs Integration just like the addons.
I seem to see many issues when people are using the addons. Not a criticism, just an observation. i have no Leviton or GE.Jasco switches but do have a Zooz one in a 3 way configuration. It has been problem free.
My DZ6HD was working perfectly on the old ZWAVE add on.
Upgraded to ZWaveJS and now i can no longer accurately see its state or control it.
Device seems like it detects correctly, but basically not functional…
Would like to say I finally got this thing working yesterday. I actually removed it last week and then adding it back it only showed as a node and wouldn’t come back to a switch. Yesterday there was a Z-wave JS update I noticed when I was just getting ready to try a firmware update I found online. The Z-wave JS update got it to finally show back as a switch and the firmware update got to finally instantly update state. For anyone with issues here is the firmware and just give a look through the thread as there may be new version, but I believe that was the one I downloaded.
