Hello. My Leviton DZS15 switches are not updating the state when I manually switch them on or off. I am a decent programmer but new to python… can’t seem to find out where in the code this is handled.
I am seeing libopenzwave callbacks when I manually turn the switch on or off but its not being picked up by the front end.
I too could not get my DZ6HD to update it’s status in HA when I was switching it on or off manually.
After a couple days of reading forums I finally understood steps. I assume this is for having it working on a rpi.
install openzwave - check the comments as there are lines to comment out to be able to compile it succesfully.
Have to associate the lifeline group of each light switch to the z-wave controller(#1 and none other) using the open z-wave control panel, click save.
Replacing the zwcfg_***.xml file from /home/pi/open-zwave-control-panel to /home/homeassistant/.homeassistant.
