Leviton integration, no device or entity for lights (new user)
I am a very new user trying to migrate over from SmartThings. I have HA 0.102.3 up and running on a Rpi4 via HASS.io.
During the initial auto discovery HA found my Leviton light switches but they didn’t switch on/off. I found the Leviton integration page and added my Leviton login to the configuration.yaml file. Now I see 2 entries for each Leviton switch. 1 works, 1 doesn’t. Also the lights don’t show up in devices or entities. Yet they popup in Node-Red service call for lights.
My question is: Is this normal? Can you explain how/where lights through integrations are stored? How/where do I delete these dupes?
ever figure this out? same issue here
I am using the wifi switches and do not have doubles and they all work. my configuration.yaml has
light:
  • platform: decora_wifi
    username: YOUR_USERNAME
    password: YOUR_PASSWORD
does your integrations tab list Leviton devices from auto-discovery ?
you’re probably responding to the op, but to answer the question from my side:
no, i dont see any devices, or entitys from this. I have the same configuration except mine is in light.yaml
however… i ended up getting it to work, i dont know how, but i noticed that it was available in nodered, with the naming from the leviton app, ‘light.office_light’ with ‘office light’ being the name from the app.
I still dont see them in home assistant, but if I manually create the automation/script/card. I am able to use it. even though it is not in entity’s or devices.
Odd behavior and from my searching it looks to be the same problem for a lot of people.
