Today we are happy to announce our first Works with Home Assistant partner: Leviton!
Leviton is an American lighting, wiring device, and load control company. Their products can be found in almost every home across the United States. As a partner, they will work with Nabu Casa to make sure that their line of Z-Wave devices will work great with Home Assistant. This gives users the best experience and will continue to give a great experience with automatic firmware updates via Home Assistant.
Leviton Z-Wave devices work locally and integrate seamlessly with the Z-Wave integration in Home Assistant (Z-Wave stick required). As all connectivity is happening locally, status updates and controlling your devices happen instantly in Home Assistant. Each device that is connected to power will also act as a Z-Wave router to extend your Z-Wave mesh network.
Leviton Decora Smart Z-Wave Devices include their DZ6HD dimmer, DZ15S switch, ZW4SF Fan Speed Controller, DZPD3 Plug-in Dimmer, DZPA1 Plug-in Switch, and ZW15R Outlet. All of these devices can be found on their Amazon store. These devices can then be used inside of your home to turn on the lights when you walk into a room, turn your bedside lamps on at a certain time, and much much more.
If you would like to learn more about the Leviton products and integration check out their integration page! Leviton will also show up in the integrations list in Home Assistant version 2022.8!
If you missed the announcement of the Works with Home Assistant partner program, make sure to check out the blog post.
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2022/07/27/leviton-partner/
