I have integrated Leviton Omnipro (HAI) into HA using the following mqtt server under Docker https://github.com/excaliburpartners/OmniLinkBridge
It runs great, but I have to run the server app on another device (a separate laptop pc), I am running HassOS on a pi 4, is there any way I could run that server under HassOS as an add-on of some sorts?
The laptop sometimes turns off and everything fails with no warning. It would be great that it would run the server on the RPi alongside HassOS.
Just getting started with Homeassistant. I also have an OmniPro II system. Did you make any progress on getting this to run without a PC?
Hey, I actually did get it run-ing on the Raspberry using an add on. In the supervisor add-on store, add this repository, and the OmniLinkBridge add on will be available for install and run on the HA server directly
https://github.com/excaliburpartners/hassio-addons
