Do the Leviton wifi switches, like the DW6HD-1BZ (Amazon, google) or DH6HD-1BZ (Apple), work with home-assistant?
I’m also interested in using these switches.
Also interested,
I installed homebridge to access assistant from homekit and vice versa, also added automation so when I set the brightness of a hue dimmer in homekit, automation will set the same brightness on leviton DH6HD, it worked, but I’m not sure how to create a virtual dimmer to use instead of hue. If anyones has an idea, I’ll be forever grateful, it will be my only temporary workaround.
Hi. I am having trouble figuring out how to do this. I can not get my DH6HD dimmers to show up in Home Assistant. How are you able to control them through HA/Hassio?
Thanks.
customized.yaml
light.basement:
custom_ui_state_card: state-card-custom-ui
state_card_mode: break-slider
stretch_slider: true
hide_control: false
show_last_changed: true
theme: happy
confirm_controls_show_lock: false
slider_theme:
min: 1
max: 200
off_when_min: true
report_when_not_changed: false
