Leviton Z-Wave 800 Switch - ZW15S - Scene ID Events?
Would anyone know how to enable Scene ID Events on this device? I have no trouble getting the Switch On/Off events, but the Scene ID Event (event.decora_smart_800_series_switch_scene_id) never triggers, no matter how many times I tap on the device.
Thanks!
That device don’t support scenes. The way I determined this was by visiting the Z-Wave Alliance product page. https://products.z-wavealliance.org/products/5007?selectedFrequencyId=2 Its the official catalogue of all Z-Wave Certified Devices. Any device that supports scenes will have central scenes listed in its supported command classes list.
This is correct regarding the specific device, but to clarify some devices do support scene functionality without Central Scene, by way of the Scene Activation CC. Examples of this are:
  1. The older GE/Jasco switches which send Scene Activation commands for 2x presses via group association to the controller
  2. The Aeon Labs (Aeotec Minimote) which is a portable scene control and can send Scene Activation commands also to the controller
The Scene Activation command includes a Scene ID, and you can use the aptly named event.foo_scene_id entities for this purpose. “scene_id” entities are not for Central Scene events, those are named after the scene ID they correspond to, e.g. event.foo_scene_001. So if there are no event.foo_scene_NNN entities, the device doesn’t support Central Scene.
Unfortunately, while Scene Activation CC is listed (on the database entry that was linked) as a supported Command Class, that only means the device can receive Scene Activation commands from another device (e.g. portable scene controller or HA). From looking at the manual, I see no way to configure it to send Scene Activation commands (that’s a quirk implemented mostly with the GE/Jasco devices before Central Scene existed). There’s currently no way for HA to know how Scene Activation is supported by a device (whether controlled or supported) so it always creates the entity even if non-functional.
As a closing note, there’s really no reason to send Scene Activation commands with HA.
Thank you this information!
