This is more of a electrical/electronics insulation/induction question.
I have this ZW15S switch(manual), and was trying to install it.
The switch is now hanging out in the air, outside of the connection box, just held by the wires & not touching anything.
The wires so far connected are Neutral, Line & Load. It is paired & works to control a lamp, either through home assistant or by tapping the switch itself
The ground is not connected yet.
What I did now was measuring the potential difference between the switch’s metallic wall mounting tab and the bare grounding wire in the box…that is one probe on the switch’s metal part of the body & other on the bare ground wire coming into the electrical box.
The multi meter reads 5V AC… I wanted to know if it is normal or not and how this can be explained.
Thanks!
