Leviton ZW15S status led not configured properly
For this new Leviton Decora switch, the “Configure” option (in the Z-Wave device configuration page) does not seem to work. Sure, I can use the button press method on the switch itself to disable the status LED. But why does the Configure option not work as it is supposed to to do this? It has no effect when I tried to use it to disable the status LED.
I noticed the same thing today and am not sure what is happening. I originally thought the switch was defective, but it seems to be a lot of people have this issue.
Did you figure out a solution?
There is a work around: you can manually program the light to operate as desired based on the manual - it involves manually pressing the buttons.
E.G. To turn off always: enter setup mode (hold top rocker pressed for 7 seconds: LED turns amber), then tap top rocker 4 times (status led flashes quickly greem/amber), then tap top rocker 3 times (status led flashes red 4 times to confirm the selection). (In the last step, instead of 3 presses: press twice for LED ON when LOAD is OFF (default), or press once for LED ON when LOAD is ON.)
I also found another option (although not very practical). After you change the configuration parameter, power cycling the unit seems to make it detect the change and react appropriately.
Unfortunately, I haven’t found any efficient way of power-cycling a light switch without resetting power to the entire circuit.
