Hello all,
I have LG TV with Broadlink mini 3 under it and I was able to learn command to power the TV. Next I made a script that turns on the smart plug which ultimately I want to switch on/ off the LG TV. The script works ok from HA. I wondered if it’s possible to use original LG ir controller to switch on/off the smart plug connected to TV (from my point of view the broadlink should listening all the time IR signals and when it receives the correct one it should run the script or automation and power up the TV - is it even possible?).
Thank you for any info or tips!
