Remembering that I did not make any configuration for him to connect the TV
Hello, I have a problem regarding the pairing with my LG TV 3700 model, at all times the Home Assistant is trying to pair with it and I do not want this pairing to occur, because every time it tries it shows a place to code preventing me from seeing what’s on TV.
Go to configuration / integrations and click the ignore
button for the discovered LG TV integration.
The problem is that my TV does not appear in these integration settings, another thing that I saw is that the TV also appears on the network as a media device, maybe it could be there that is causing this problem!
![Screenshot_1](https://community-assets.home-assistant.io/original/3X/c/e/cee33520ce7de4b611389b76b392c30b5dbf97b6.jpeg)
I am also having the same problem with an older LG TV.
quite frustrating.
I have the same issue with an older LG TV. Did you find any solution for this issue?
Same problem on my LG 32LW5590-ZE. Just started using Home Assistant but this is very annoying. Spamming thisrequest every 10 minutes. I tried the ignore and pair then disable function without any result. Any idea?
