I’m experiencing the below issue with my LG TV since I’ve updated from 0.33 to 0.35 (not sure if the issue was there in 0.34):
File "uvloop/future.pyx", line 374, in uvloop.loop.BaseTask._fast_step (uvloop/loop.c:105920)
File "/usr/src/app/homeassistant/helpers/entity_component.py", line 386, in _update_entity_states
yield from update_coro
File "/usr/src/app/homeassistant/helpers/entity.py", line 216, in async_update_ha_state
yield from self.hass.loop.run_in_executor(None, self.update)
File "uvloop/future.pyx", line 230, in __iter__ (uvloop/loop.c:103945)
File "uvloop/future.pyx", line 432, in uvloop.loop.BaseTask._fast_wakeup (uvloop/loop.c:107104)
File "uvloop/future.pyx", line 101, in uvloop.loop.BaseFuture._result_impl (uvloop/loop.c:102363)
File "/usr/local/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/usr/src/app/homeassistant/util/__init__.py", line 296, in wrapper
result = method(*args, **kwargs)
File "/usr/src/app/homeassistant/components/media_player/lg_netcast.py", line 86, in update
from pylgnetcast import LgNetCastError
File "/usr/local/lib/python3.5/site-packages/pylgnetcast/__init__.py", line 3, in <module>
__all__ += pylgnetcast.__all__
NameError: name 'pylgnetcast' is not defined
I went to the docker image and checked the version. Eventually I removed the dependency hoping HA will download it again updated, and looks like it worked but I now have this new error:
2016-12-28T16:45:38.362693296Z Traceback (most recent call last):
2016-12-28T16:45:38.362711571Z File "/usr/src/app/homeassistant/helpers/entity_component.py", line 150, in _async_setup_platform
2016-12-28T16:45:38.362728722Z entity_platform.add_entities, discovery_info
2016-12-28T16:45:38.362744797Z File "uvloop/future.pyx", line 230, in __iter__ (uvloop/loop.c:103945)
2016-12-28T16:45:38.362761810Z File "uvloop/future.pyx", line 432, in uvloop.loop.BaseTask._fast_wakeup (uvloop/loop.c:107104)
2016-12-28T16:45:38.362798086Z File "uvloop/future.pyx", line 101, in uvloop.loop.BaseFuture._result_impl (uvloop/loop.c:102363)
2016-12-28T16:45:38.362825162Z File "/usr/local/lib/python3.5/concurrent/futures/thread.py", line 55, in run
2016-12-28T16:45:38.362842788Z result = self.fn(*self.args, **self.kwargs)
2016-12-28T16:45:38.362859025Z File "/usr/src/app/homeassistant/components/media_player/lg_netcast.py", line 48, in setup_platform
2016-12-28T16:45:38.362875751Z from pylgnetcast import LgNetCastClient
2016-12-28T16:45:38.362891864Z ImportError: cannot import name 'LgNetCastClient'e[0m
Well, I must confess I don’t know what I’ve done (if anything at all) but it’s no longer showing this error.
It’s weird because all he issues came from my dev environment, in prod looks like everything goes fine. Just to note here, he difference between CV and pro for me is very small, both envs are docker containers in he same box. The config is a simple copy and paste from prod to dev where I test stuff …
