Hi Everyone,
I had some issues installing and using the GitHub - sampsyo/hass-smartthinq: Home Assistant component for LG SmartThinQ HVAC devices integration, because it didn’t work for me.
I’ve been searching for a solution for the integration of our 2 LG Airco units. and found one that work perfectly! The units that we have are the “LG PC09SQ NSJ” (S3NM09JA2FA) and the “LG PC18SQ NSK” (S3NM18KL2FA) both running softwareversion 16.32 that can be found in the Smartthinq app.
The one that works for us and its already posted but still wanted to add the following info about our system:
Home Assistant
version: core-2021.5.4
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.9
os_name: Linux
os_version: 5.4.83-v8
arch: aarch64
host_os: Home Assistant OS 5.13
update_channel: stable
supervisor_version: supervisor-2021.04.3
docker_version: 19.03.15
supported: true
board: rpi4-64
HACS
Integration version:1.12.3
Frontend version: 20210429001005
SmartThinQ LGE Sensors
Version: 0.7.1
And must say that the installation and setup was easy and it worked immediately!
*Edited some typos
