If I enable the Remote Start from the washer, and a few hours later want to start it from an automation it fails with the error code (switch.turn_on, as the machine has gone into sleep mode)
Error: {‘data’: None, ‘voiceData’: None}
I have tried to mitigate this by adding continue_on_error: true but the automation still aborts.
If I manually operate the washer from the device controls in HA it works as intendes, if I try it out in Developer Tools > Actions the switch.turn_on throws an error but the washer is turned on never the less.
I have tried with the integratio wake up, but that fails all together (smartthinq_sensors.wake_up).
It does wake up, and if I operate it from the device in Ha all works as intended.
If I operate it from actions (either from automation or Developer) the power_on and wake_up both generates an error
Trail and horror…
The action switch.turn_on is sent to the machine, and it goes into waken standby mode, however the
is ignored by the automation, which aborts. Relauncing the automation a (few) minute(s) later results in the intended result, ie the washer to actually start.
So, how is the continue_on_error intended to work here? Is it the usage of IF-condition that breaks it?
If I can’t get the continue_on_error to work properly, then the only remaining option is to fire one additional automation based on the exit code of the first automation.
As an interim solution I selected to put the switch.turn_on in an one liner script, it does fail, but as it is external from the automation which then survives the error and continues as intended.
