If I’m here, it’s because I need help.
Until now, I’ve managed my ThermaV using:
https://community.home-assistant.io/t/lg-therma-v-heat-pump-modbus-control/496233/14
Today, I want to take it a step further, eliminating the cables.
I connected everything according to the following diagram:
I’m trying with this code
esphome:
friendly_name: ThermaV
esp8266:
board: esp01_1m
board: esp12e
web_server:
port: 80
Enable logging
logger:
Enable Home Assistant API
api:
encryption:
key: “dpikk/FwBH1bIuxr9+ICdjEQ8Hkt99Y4NTPtgOIjqJs=”
ota:
- platform: esphome
password: “ba1c68503c956312fb5dd7347c219d45”
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.215
gateway: 192.168.1.1
subnet: 255.255.255.0
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Thermav-Modbus Fallback Hotspot”
password: “pRHTh2LP6EUq”
captive_portal:
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 9600
stop_bits: 1
data_bits: 8
parity: NONE
modbus:
uart_id: uart_bus
send_wait_time: 500ms
modbus_controller:
- id: modbus_device
address: 0x1 # Set to the Modbus address I confirmed works with the RS485 to USB
modbus_id: modbus1
setup_priority: -10
update_interval: 30s # Adjust the polling interval as needed
platform: modbus_controller
modbus_controller_id: modbus_device
name: “T °C Set”
register_type: holding
address: 0x24 ## address of the register inside the Modbus slave device
unit_of_measurement: “°C”
value_type: U_WORD -
address: 0x26 ## address of the register inside the Modbus slave device
register_type: read
address: 0x10 ## address of the register inside the Modbus slave device
name: "°C Evaporatore "
address: 0x11 ## address of the register inside the Modbus slave device
name: "°C Esterno "
address: 0x12 ## address of the register inside the Modbus slave device
name: "°C Scambiatore "
address: 0x14 ## address of the register inside the Modbus slave device
name: "°C Ritorno "
address: 0x15 ## address of the register inside the Modbus slave device
name: "°C Mandata "
address: 0x16 ## address of the register inside the Modbus slave device
address: 0x20 ## address of the register inside the Modbus slave device
unit_of_measurement: “°Hz”
name: "Hp R32 "
unit_of_measurement: “Kpa”
name: "Lp R32 "
address: 0x21 ## address of the register inside the Modbus slave device
register_type: coil
address: 0x2 ## address of the register inside the Modbus slave device
register_type: coil
address: 0x3 ## address of the register inside the Modbus slave device
register_type: coil
address: 0x4 ## address of the register inside the Modbus slave device
value_type: U_WORD
Unfortunately it doesn’t work and the log returns :
'[17:34:17][C][captive_portal:089]: Captive Portal:
[17:34:17][C][web_server:285]: Web Server:
[17:34:17][C][web_server:285]: Address: 192.168.1.215:80
[17:34:17][C][esphome.ota:073]: Over-The-Air updates
[17:34:17][C][esphome.ota:073]: Address: 192.168.1.215:8266
[17:34:17][C][esphome.ota:073]: Version: 2
[17:34:17][C][esphome.ota:080]: Password configured
[17:34:17][C][safe_mode:018]: Safe Mode:
[17:34:18][C][safe_mode:019]: Boot considered successful after 60 seconds
[17:34:18][C][safe_mode:019]: Invoke after 10 boot attempts
[17:34:18][C][safe_mode:019]: Remain for 300 seconds
[17:34:18][C][api:182]: API Server:
[17:34:18][C][api:182]: Address: 192.168.1.215:6053
[17:34:18][C][api:187]: Using noise encryption: YES
[17:34:18][C][mdns:122]: mDNS:
[17:34:18][C][mdns:122]: Hostname: thermav
[17:34:18][C][modbus_controller:349]: ModbusController:
[17:34:18][C][modbus_controller:349]: Address: 0x01
[17:34:18][C][modbus_controller:349]: Max Command Retries: 4
[17:34:18][C][modbus_controller:349]: Offline Skip Updates: 0
[17:34:18][D][modbus_controller:039]: Modbus command to device=1 register=0x24 no response received - removed from send queue
[17:34:21][D][modbus_controller:039]: Modbus command to device=1 register=0x26 no response received - removed from send queue
[17:34:23][D][modbus_controller:039]: Modbus command to device=1 register=0x10 no response received - removed from send queue
can anyone find the mistake
