Guys, what happened in one of the latest HA release? I used custom lg remote control many days in the past and now I’ve got an error “you need to difine MAC address”
Please read the 2022.2 release thread.
Thanks, found and fixed.
Not sure what the mentioned fix is? Could you elaborate, please?
Nevermind, found you need the ‘mac: xx:xx:xx:xx’ in the actual card configuration - seems unnecessary considering below:
I’m not using wake on lan, but rather an IR remote service for the webostv.turn_on trigger - this works with standard media card, but not this custom one (latest release).
I’m using wake on lan and Mac was already defined in config. Only because of that I created post. My problem was in configuration of ui plug-in (it requested update and defining tv MAC address inside it configuration)
Understood, thank you.
I was just saying the card should not fail (maybe just the turn on should not work). It is a custom component and I do appreciate the effort.
Btw, turn on works only in case your tv using Wi-Fi. I don’t know why but there is no option in tv to wake up on Ethernet
