This has got to be one of the most awesome additions to HA although HA is already very cool.
I do have an issue and a feature request.
The Issue is that the button for my disneyplus doesn’t work any idea on how to fix that.
The feature request would be to be able to have a one button acces to the timer of the TV.
Through HACS the only frontend plugin i see available is " LG WebOS channel pad" which is different to the ‘LG WebOS Remote Control’ that the github readme says.
I installed the LG WebOS channel pad through HACS anyway, i then added;
Custom element doesn't exist: lg-remote-control.
type: 'custom:lg-remote-control'
entity: media_player.living_room_tv
Is there something going wrong with the naming of the components here? “lg-remote-control” versus “LG-WebOS-Remote-Control” versus “LG WebOS channel pad”.
Anyone able to give a bit of insight on where i might be going wrong.
these two components are required for full operation of the remote control.
the first is the remote control, the second allows you to view a list of channels you have configured
Thanks for the pointers, i’ve just had another look at this.
I’ve now ensured that i have both the WebOS Remote Control and WebOS channel pad installed.
$ pwd
/root/config/custom_components
custom_components $ ls -l card-channel-pad/
total 144
-rw-r--r-- 1 root root 143516 Jan 1 20:59 card-channel-pad.js
custom_components $ ls -l LG-WebOS-Remote-Control/
total 488
-rw-r--r-- 1 root root 496597 Jan 1 20:50 lg-remote-control.js
Confirming that both of these are added to the Lovelace resources page:
I copied some of your examples just to test the integration was working, i substituted my entity in for yours, but i’m getting “No card type configured”, along with the “custom element doesn’t exist”:
Ok got a little bit further this time, i reinstalled both components through HACS, and noticed others mentioning browser_mod, so i installed that too.
Borrowing Sergei’s code (post 34) as his entity name is identical to mine, and i can now see a graphical representation of the remote, but i’m getting an error that’s preventing me to save it: “Error: No visual editor available for: custom:lg-remote-control”
Just to finalise, Sergei’s code had one too many quotes in the title, but also found out after doing some searches that preview rarely works on custom cards and to just stick the code in the raw lovelace config.
Just need to figure out why some buttons don’t work now.
Has anyone else had a problem with the Power button? Everything else on the controller works great, but I can’t get it to actually turn the TV off or on.
Edit:
Solution: Add the “wake_on_lan:” to the configuration.yaml file
# Enables "Wake on LAN" for WebOS TV
wake_on_lan:
# LG WebOS TV Config
webostv:
host: xxx.xxx.xxx.xxx
name: Man Cave TV
turn_on_action:
service: wake_on_lan.send_magic_packet
mac: xx:xx:xx:xx:xx:xx
I have a question… is this only me, or do you get the same “problem” when seeing the remote on my phone… the icons shift a bit to right… are note cantered
I was getting this error with my Raspberry setup.
The strange solution was to rename the folder from “LG-WebOS-Remote-Control” to something lowercase like “lg-remote-control”.
After updating the resource url and a full restart, the remote suddenly appears on my dashboard.
first let met tell you this remote looks very cool to me.
however I can’t get it to work.
I think I do something wrong
I get this error:
“Custom element doesn’t exist: lg-remote-control”
My resources look like this:
I copied the files using ssh.
But I think I don’t have them copied to the correct location.
the copy location is the one in the screenshot. Can someone help me out?
Edit:
I got some working.
Read something about HACS. so I installed and used that one.
then I found somthing about slashes
So strange, this is mine. Native Plex app is installed on the TV.
source_list:
Amazon Prime Video
Live TV
Netflix
YouTube
volume_level: 0.15
is_volume_muted: false
media_content_type: channel
media_title: ‘’
source: Live TV
sound_output: tv_speaker
friendly_name: Living Room TV
supported_features: 20413
device_class: tv
