capivara
(Marcio)
April 4, 2023, 3:01pm
1
I just bought a LG OLED55C2PSA TV, and as soon as I turned it on and plugged it in the local network HA asked to set up the LG WebOS TV integration, which worked fine for the HA. I can turn it on (WOL), off, switch input channels, change the volume. But the thing is, the TV won’t show on the Google Home app, nor the Alexa app, so I cant control the TV with assistant’s voice commands. Everything else shows up normally. Also I subscribe to the Nabucasa subscription and never had any problem getting devices to show up on the assistants.
I found this 2020 issue and it seems that the TV should appear on Google Home naturally after using the LG WebOS integration.
opened 11:51AM - 05 May 20 UTC
closed 06:09PM - 16 Aug 20 UTC
integration: google_assistant
stale
<!-- READ THIS FIRST:
- If you need additional help with this template, pleas… e refer to https://www.home-assistant.io/help/reporting_issues/
- Make sure you are running the latest version of Home Assistant before reporting an issue: https://github.com/home-assistant/core/releases
- Do not report issues for integrations if you are using custom components or integrations.
- Provide as many details as possible. Paste logs, configuration samples and code into the backticks.
DO NOT DELETE ANY TEXT from this template! Otherwise, your issue may be closed without comment.
## The problem
Describe the issue you are experiencing here to communicate to the
maintainers. Tell us what you were trying to do and what happened.
I implemented this 2 integration
1) https://www.home-assistant.io/integrations/webostv/
2) https://www.home-assistant.io/integrations/google_assistant/
and now I'm able to see a card on lovelace in witch I can control the TV, for example turn on/off, set volume up/down, change source channel.
I'm able to turn on/off the TV using google assistant.
From the documentation of webos integration I can see
media_player (on/off/set volume (via set volume)/source (via set input source))
So I should be able to set volume and channel with google assistant if I understand well.
How can I? Maybe I simply don't know the vocal command to give to Google Assistant or maybe I'm missing something else?
## Environment
Provide details about the versions you are using, which helps us to reproduce
and find the issue quicker. Version information is found in the
Home Assistant frontend: Developer tools -> Info.
- Home Assistant Core release with the issue: 109.3
- Last working Home Assistant Core release (if known): none
- Operating environment (Home Assistant/Supervised/Docker/venv): HASSIO
- Integration causing this issue: webos/google assistant
- Link to integration documentation on our website:
## Problem-relevant `configuration.yaml`
An example configuration that caused the problem for you. Fill this out even
if it seems unimportant to you. Please be sure to remove personal information
like passwords, private URLs and other credentials.
```yaml
google_assistant:
project_id: xxxxxxxxxxxxxxxxxxxx
service_account: !include XXXXXXXXXXXXXXX.json
exposed_domains:
- media_player
webostv:
host: 192.168.XXX.XXX
turn_on_action:
service: wake_on_lan.send_magic_packet
mac: "XX:XX:XX:XX:XX:XX"
customize:
sources:
- livetv
- youtube
- netflix
- Amazon Prime Video
- Disney+
- hdmi1
- hdmi2
- hdmi3
- spotify
## Traceback/Error logs
If you come across any trace or error logs, please provide them.
```txt
## Additional information
Can someone help me fix this?
