LG WebOs Smart Tv Integration - Multiple Tvs
Hi
I’m trying to figure out how to use multiple TVs and probably using the code incorrectly.
Please help me to figure out what should be changed.
as long as it only one tv, it works perfectly and compiling. but when using two \ more TVs it doesn’t.
webostv:
  -name: Main RoomTv
  host: 192.168.0.119
  #other settings
  turn_on_action:
    service: wake_on_lan.send_magic_packet
      mac: "58-FD-B1-44-89-9S"
      broadcast_address: 192.168.0.119
    -name: Room1Tv
    host: 192.168.0.111
    #other settings
    turn_on_action:
        mac: "58-FD-B1-57-55-9S"
        broadcast_address: 192.168.0.111
media_player:
notify:
I currently integrate 4 LG WebOS TVs. Try this configuration below-
webostv:
  - name: Main Room TV
    host: 192.168.0.119
    turn_on_action:
       mac: 58-FD-B1-44-89-9S
  - name: Room 1 TV
    host: 192.168.0.111
    turn_on_action:
       mac: 58-FD-B1-57-55-9S
Also, add this-
wake_on_lan:
Note:
  1. Make your TV IP address static (either through DHCP reservation / manually using TV setting)
  2. Make sure the indentation is correct
Thanks!
I’ll try that.
By the way, can I set Static IP manually using the TV settings when using Wireless connection?
Yes, I think you can. Make note of your current router’s DHCP server IP range. Then, insert a static IP address outside of the DHCP server IP range.
Please note that if you are using wireless connection, Wake On Lan may / may not work.
