It’s my first topic on this forum, I’ve installed my Home Assistant a few weeks ago and I have a lot of trouble on the configuration.
For instance, we’re using mostly Apple Product and Siri at Home so this is why we want to make everything available through the Home App.
But I have some trouble making my TV available. In fact, it’s available and I can turn it off/on (wake_on_lan). But no matter what I try, the icon in the Home App is always a small Home instead of a TV. Also, sometime when restarting Home Assistant to test things, the inputs of the TV change to the name of the TV or the name of the room. (It seems to be random tbh)
homeassistant:
customize: !include customize.yaml
webostv:
host: !secret tv_ip
turn_on_action:
service: wake_on_lan.send_magic_packet
mac: !secret tv_mac
customize.yaml
media_player.lg_webos_smart_tv:
friendly_name: Main TV
device_class: tv
source_list:
- HDMI 1
- Apple TV # HDMI 2 (eARC - CEC)
- HDMI 3
- HDMI 4
- USB
homekit.yaml
filter:
include_entities:
- media_player.lg_webos_smart_tv
entity_config:
I’m asking for help after hours and hours spent this week with no result, I’m wondering if it’s a bug or if it’s just something that goes wrong between my keyboard and my chair…
But sometime it update, for instance now the source appear with their right names defined in the customize.yaml
(There’s always the right number of input based on the source I’ve setup even if they have the wrong name)
But still the icon is not a tv…
So I think it definitely affect, but you may be right, maybe there’s a conflict somewhere between GUI and YAML.
How do i know about what is configured in GUI instead of yaml ? Right now I’m adding my new device using the “device and services” menu where it discover my devices and then I go in the yaml to configure them.
Am I doing something wrong ?
Yup, that is because the TV is on and it then extract the values from there. Your YAML should have no effect.
Regarding the house in HomeKit, then I do not know, since I do not use Apple products, but I know LG WebOS TVs also have a builtin smart home control hub, so that might be why it shows as a house.
The only issue is the wrong icon in the Apple Home app and sometime the inputs that appear with the tv or room name (still in home app) ignoring the configuration… (But if I’m patient the inputs will finally change magically).
Oh and another issue, in the home app the current input is wrong, I can’t figure why.
The YAML is a deprecated configuration form.
You might have found a guide to an earlier version of HA, but HA have moved a lot since then and one of the moves is to deprecate YAML setup and use GUI instead.
Really ?? I thought the UI was a user friendly alternative for non tech guys but that yaml still offer 100% of features.
I mean I did my own keyboard using QMK and there is an GUI based configuration and a programming alternative in C with way more option, I thought it would be similar.
I’ll try to move the config in full GUI then, I’ll let you know.
