Trying to automate the garage doors, so that when the webcamera in the backyard recognize the correct license plate, the garage door should open. If I check the states the image processing recognize the right plate, but the automation never fires. Followed the documentation for image processing, The automation is as follows:
- alias: Open garage door
platform: event
event_type: image_processing.found_plate
event_data:
entity_id: openalpr.camera_ip_webcam
plate: *******
service: cover.close_cover
entity_id: cover.mini
If I trigger the automation manually, it does as intended.
Seems like there is not a lot of people that have been using this feature before, so could not find anything helpful. Anyone that knows what should be different?
