Button “press” does not represent status of the physical button.
Can you ring the bell physically and show the history statuses of sensor “las_zone” that is displayed on your screenshot? Just click on it it should show history. Same is visible on the last screenshot - history logs for that device. (Isn’t that the single event that was fired there? That would be the trigger for your automations).
Just ring it and show the output.
The Single event is from pressing the button indeed.
You are right that eventhough it triggers something else I can still use it as a trigger fir the automation.
But I have checked and it is not an option to use in the automation.
I am not good in coding in yaml yet.
Any idea how to use it as an trigger?
No that is the sensor that shows if the doorbell is attached to the wall
it shows the correct trigger in the log but you cant seem to use it as a trigger in any of the automations
