I have Lidl remote hg08376 from the following pack:
The problem is that after the button “ON” is pressed, the remote doesn’t send any subsequent additional events when pressing the button “ON”. It seems that sometimes the remote forgets its state and in order to turn on lights I need to press “OFF” first and then “ON”.
I am using zigbee2mqtt and when I press “ON” multiple time - then only first button press is displayed in logs.
Tested on multiple different remotes - same result. Doesn’t happen to “OFF” button, I can press it multiple times and all presses will be registered.
Does somebody have the same problem?
