I’m new to this forum and just trying to work out the Life360 device tracker.
I’ve managed to set it up within Home Assistant using the UI and I can see in the Home Assistant log that it is definitely working as I can see the following entry:
(SyncWorker_12) [homeassistant.components.life360.device_tracker] Updating life360_adam
But I can’t seem to find any entity with this device_tracker and when I go in to persons I don’t have any available device trackers except for the one from my netgear Orbi.
Any ideas on what I need to do would be greatly appreciated.
Unfortunately this is a common problem. It seems people always set trace_new_devices to false when they use router-based trackers and forget later when they add other trackers that that setting is a global setting that affects all trackers. Glad you figured it out and got it working.
