Life360 app now causes Home Assistant to crash. Also Apps will not load
I updated HA core to the latest this morning and I can no longer access Settings/Apps.The cursor just continually spins. All other settings pages load normally. Also, Life360 prevents me from restarting HA. If I comment out Life360 in config.yaml, I can restart normally. I am running HA supervisor 2023.06.1 with 10.2 operating system on a Nuc (not thru Proxmox or the like.
Can anyone please help?
thanks
I had the same problem, look at the logs, remove the settings from Configuration.yaml that solves it, your settings are already imported into the user interface, your sensors will not disappear.
The Life360 integration has not supported configuration via YAML since the 2022.7 release. See the Life360 section under the 2022.7 Release Breaking Changes.
Many thanks. All sorted now.
