How to I make life 360 cards in Lovelace? Like battery, etc… do I have to make sensors for everything? Because all I see are available entities
if you want all of the attributes of the entity to be seen on their own lines then you will have to create a sensor for each entity/attribute that you want to see.
Or you can use an “attribute entity” custom card in lovelace that will show all the attributes for an entity in a table format.
Thank you, my biggest struggle with HA is I see a lot of config docs, but no real world examples. I’ve made a sensor before but not sure how to start a life360 one.
