Just reading the release notes on 89.1 and I noticed the custom component path change. I don’t understand enough of the back end of the project to know this answer for sure - I use the Life360 custom component, has anyone had any experience with this component with 89.1, will it still work?
I’m not on my main pc at home, but if I remember correctly, you have to create a life360 folder and then put the device_tracker.py file in there under the custom_components folder for it to work.
I currently have it as custom_components/device_tracker/life360.py which is probably what you meant since you’re not in front of your setup - just double checking
