Testers are no longer needed. The changes have been incorporated in the 2022.7.0 release.
Thanks to everyone who tried it out and/or provided feedback!
The Life360 Integration is a “legacy” device tracker, meaning it still uses the old Device Tracker mechanisms. E.g., it still uses the known_devices.yaml
file. I’ve worked on updating it to the new “entity based” mechanism (like many device tracker integrations did back in the 0.94 days.) This change is long overdue.
Before submitting it for inclusion in an upcoming Home Assistant release, I’d like to get some people to test it out (besides myself) to make sure I didn’t overlook anything, and to get feedback if there are any minor tweaks users might want.
If you use the Life360 integration, and would be willing to test the changes for me and provide feedback (good or bad), then check out a custom integration version in this github repo. Please provide feedback here, or on that repo’s Issues page.
NOTE: This test project only supports the English language configuration (which should not be confused with “English (GB)”.)
If you are using any other language selection, then you should do one of the following, or you should probably not try to use this.
- Temporarily change your configuration to “English”.
- Copy
en.json
incustom_components/life360/translations
to another file appropriate for your language configuration. (Sorry, can’t really help here as to what to name the new file.) Optionally edit the new file to translate the strings to your language.
