Life360 error: Location information missing
Hi
I installed the life360 integration, opened an account, allowed location sharing, but I get the following error in HA log:
Accordingly, nothing appears in my device trackers under “People”.
Any ideas how to solve this?
Try adding the following to your configuration, restart, and see if there are any useful messages in home-assistant.log:
logger:
  default: info
  logs:
    life360: debug
    homeassistant.components.life360: debug
Alternatively you should be able to enable these by using the logger.set_level service from Developer Tools.
Hi Phil,
I have the same problem and the logging showed this:
homeassistant.components.life360.device_tracker
Source: components/life360/device_tracker.py:166
Integration: Life360 ([documentation](https://www.home-assistant.io/integrations/life360), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+life360%22))
First occurred: 21:25:09 (2 occurrences)
Last logged: 21:25:21
* life360_till_bremke: Location information missing
* Suppressing further errors until OK: life360_till_bremke: Location information missing
So this leads to not showing any new entity.
What can I do to make it work?
Best regards Till
