So i’m playing with life360, and i monitor when “Place” goes from Home to null or vice versa. I have the time set for 00:00:01.
Doesn’t seem to work though. I’ve set it now to a minute, maybe that helps, it might be that a second is not enough? It’s definitely the right attribute to monitor though.
Ah so i just checked, you’re right there is a state for the entity itself, as being home or not_home. Then you can optionally specify attributes, which is what i did. But that’s not working for some reason.
I added yours, see if that works. I’d still like to verify things like Place though, so i know where someone is.
