Life360 - integration has not working
'api-cloudfront.life360.com', 'user-agent': 'com.life360.android.safetymapd', 'Accept': 'application/json', 'cache-control': 'no-cache', 'Authorization': 'Basic Y2F0aGFwYWNyQVBoZUtVc3RlOGV2ZXZldnVjSGFmZVRydVl1ZnJhYzpkOEM5ZVlVdkE2dUZ1YnJ1SmVnZXRyZVZ1dFJlQ1JVWQ==', 'Accept-Encoding': 'gzip, deflate', 'Cookie': '__cf_bm=GWlVYgM2sHNUEVY..JmoBYKav2gVzUASU1xRSFz3Mac-1700416607-0-ATJXtWPaF+E9vGVwuEWQ/QyfiDnv4UA97jNOMOKR46E2YsOFXFS6OsNwUE5kFAggEs4KPZx4lES+SL8RSkueIFI=', 'Content-Length': '82', 'Content-Type': 'application/x-www-form-urlencoded')>, real_url=URL('https://api-cloudfront.life360.com/v3/oauth2/token.json')), (), status=403, message='Forbidden', headers=<CIMultiDictProxy('Date': 'Sun, 19 Nov 2023 17:59:50 GMT', 'Content-Type': 'text/html; charset=UTF-8', 'Transfer-Encoding': 'chunked', 'Connection': 'keep-alive', 'X-Frame-Options': 'SAMEORIGIN', 'Referrer-Policy': 'same-origin', 'Cache-Control': 'max-age=15', 'Expires': 'Sun, 19 Nov 2023 18:00:05 GMT', 'Vary': 'Accept-Encoding', 'Server': 'cloudflare', 'CF-RAY': '828a596b298700b4-DME', 'Content-Encoding': 'gzip', 'alt-svc': 'h3=":443"; ma=86400')>)
2023-11-19 20:59:50.298 DEBUG (MainThread) [homeassistant.components.life360] Login error: ClientResponseError: 403, message='Forbidden', url=URL('https://api-cloudfront.life360.com/v3/oauth2/token.json')
What version of HA Core are you running?
If you can’t solve this problem, you could try removing the Life360 integration from HA and adding it back in. If that still doesn’t work, try removing it, changing your Life360 password via the Life360 app or website, then adding the Life360 integration back in HA using the new Life360 password.
  • Core2023.11.1
  • Supervisor2023.11.3
  • Operating System11.1
  • ĐŸĐŸĐ»ŃŒĐ·ĐŸĐČĐ°Ń‚Đ”Đ»ŃŒŃĐșĐžĐč ĐžĐœŃ‚Đ”Ń€Ń„Đ”Đčс20231030.1
Life360 integration is not installed
I am not sure what you mean. If you haven’t added the Life360 integration to Home Assistant, you clearly shouldn’t get any errors.
Can you explain what you have tried to get the Life360 integration working on Home Assistant, and if you are still getting any errors, can you share those details?
I didn’t install life360
I didn’t delete live360
I’m installing live360 for the first time
I put the full registration when entering the data identifier
2023-11-27 17:16:45.267 DEBUG (MainThread) [life360.api] Error while getting authorization token, attempt 1: ClientResponseError(RequestInfo(url=URL('https://api-cloudfront.life360.com/v3/oauth2/token.json'), method='POST', headers=<CIMultiDictProxy('Host': 'api-cloudfront.life360.com', 'user-agent': 'com.life360.android.safetymapd', 'Accept': 'application/json', 'cache-control': 'no-cache', 'Authorization': 'Basic Y2F0aGFwYWNyQVBoZUtVc3RlOGV2ZXZldnVjSGFmZVRydVl1ZnJhYzpkOEM5ZVlVdkE2dUZ1YnJ1SmVnZXRyZVZ1dFJlQ1JVWQ==', 'Accept-Encoding': 'gzip, deflate', 'Content-Length': '81', 'Content-Type': 'application/x-www-form-urlencoded')>, real_url=URL('https://api-cloudfront.life360.com/v3/oauth2/token.json')), (), status=403, message='Forbidden', headers=<CIMultiDictProxy('Date': 'Mon, 27 Nov 2023 14:16:45 GMT', 'Content-Type': 'text/html; charset=UTF-8', 'Transfer-Encoding': 'chunked', 'Connection': 'keep-alive', 'X-Frame-Options': 'SAMEORIGIN', 'Referrer-Policy': 'same-origin', 'Cache-Control': 'max-age=15', 'Expires': 'Mon, 27 Nov 2023 14:17:00 GMT', 'Set-Cookie': '__cf_bm=DrMr._xuWgfJFsIsL2Q61q2oHXBCNrcZVb5.U0.haG0-1701094605-0-AUiFiQaoJL1eD7/vhOJXhwNfI3R4MON1o50xtel2dkV1nh9jDsv3LKJgtOG7F4oqJu1MaF/gg/okNqmF+YOy44E=; path=/; expires=Mon, 27-Nov-23 14:46:45 GMT; domain=.life360.com; HttpOnly; Secure; SameSite=None', 'Vary': 'Accept-Encoding', 'Server': 'cloudflare', 'CF-RAY': '82cafda2af1f9d96-DME', 'Content-Encoding': 'gzip', 'alt-svc': 'h3=":443"; ma=86400')>)
Ok, I understand you’re trying to add Life360 to HA for the first time.
When you enter your credentials, are you using an e-mail address & password, or a phone number & password?
The only way I can explain getting that error is that the username (email address) & password you’ve entered are not a valid Life360 account. Try using them here:
Life360 | Login
Make sure to click on the little “Use email instead” link under the phone number box.
Are you sure you’ve entered them correctly (i.e. no typos)?
Yes. that’s right. I can log in to the official website with my credentials
Sorry, then I have no idea why the HA Life360 integration isn’t working for you. It’s always possible Life360 has started to block unsupported usage like other services have.
Did you manage to fix this? today i checked and my existing HA and was having error with life 360 not working. It seems that it thinks password is incorrect l. I changed the password for my life360 account and its still not work. I did notice that when i login to mobile app for life 360 it sends me one time pass code so I wonder is this is causing a problem. Its a shame as it is very useful for HA location notifications on my home speakers. I had it setup so it announced when why wife or kuds were home.
unfortunately it doesn’t work
shame on the author
support what you do as others do
I found other ways to track
life360 works very poorly on iphone
Excuse me?
There are literally dozens of community forum topics and several core issues on which the current state of affairs has been discussed and detailed. I, with the help of others, have tried very hard to keep the integration working, but if you read any of the other related topics & issues, you’ll see that Life360 has taken steps to lock out third party applications such as Home Assistant and others. We were able to keep the integration limping along for a while, but the latest steps by Life360 & Cloudflare cannot be easily worked around. Even Paulus has said it’s time to give up. Therefore, the HA Life360 integration has been removed, starting with the upcoming 2024.2 release.
Shame on you for making such statements without doing your research.
so is definitively the end if life360 on HA ?
Yes, at least for now. There have been some attempts at trying to work something out with Life360, but it doesn’t look like that will happen anytime soon, if it happens at all. Their official stance, at least at this point, is that they do not support home automation systems, and that includes the “big” players (like Google, Alexa, IFTTT, etc.) as well.
@pnbruckner, don’t Listen to other people. You did a great job. I even tried to sniff the app all afternoon just realizing that it won’t work :thinking:
Anyways, thank you very much for all your efforts and support.
Waiting for other integrations that you’ll be involved with :grin:
:smiley: Well, then you might want to check out:
And, of course, there’s always:
And a relatively new one:
Will Check them out :grin: thanks
