The Life360 integration is currently not functioning again and claiming it needs to be reconfigured or could not configure itself.
What version of HA are you using?
Supervisor 2023.10.0
Operating System 11.0
Frontend 20231005.0 - latest
Waiting on SSD to update less than 2gb remaining space. Literally not possible rn. No backups on device.
If you get your system working again and still have problems with life360, let me know if there are any error messages in the system log (besides what you already described.) Worst case, you may have to change your Life360 password (via the Life360 app or website), and then try again. I’m not sure why this is sometimes necessary, but there has been some evidence that this may be the only way to get it working again in some instances.
Yeah still not working after everything.
Did you delete the integration and try adding it again?
If it still doesn’t work, please share associated error messages from the system log.
Also, please enable debug for the integration and share any related debug messages from the system log. You won’t see these unless you load or download the entire log.
