Life360 update rate
I’m seeing that the rate of when life360 is updating is not very high. I like to get it updated every 15 sec. Is that possible?
The integration queries the server every 10 seconds. When the server has new location data is determined by it and your phone and depends on many things, such as if your phone is moving.
Yeah okay, I also saw a other post where you can set your own rate with interval_seconds but I cant find how I do configure life360 via configuration.yaml it isn’t anymore one Life360 - Home Assistant
Changing how often the HA Life360 integration queries the Life360 server won’t do much (and, as you found, is not possible without modifying the code. That is by design as directed by the HA core development team.) Your phone settings, and your movements (with that phone), have way more to do with how often new location data will be available to the HA Life360 integration. I suggest you read Life360’s FAQs.
