Hi a
Getting regular (~80% of restarts) errors with the LIFX platform. The error stops hassio booting at all, getting the following in the logs:
ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/aiolifx/aiolifx.py", line 278, in try_sending
self.transport.sendto(msg.packed_message)
File "uvloop/handles/udp.pyx", line 157, in uvloop.loop.UDPTransport.sendto
AttributeError: 'uvloop.loop.UDPTransport' object has no attribute '_address'
Tried adding server (being RPi IP address) in the lifx platform config with no success and going bit crazy!
Thanks for any help.
Hassio 0.81 provides an integration for LIFX that works fine for me now - remove the platform: lifx config and just configure the integration through Hassio instead.
Hizzah!
Oooh, maybe hold on that. It did work but after a restart looks like same error again - and now as it’s not it in my config I don’t know how to undo it (Hassio won’t start so can’t get to Integrations!) .
