For some time now, I’ve been wanting to automatically have my lights change in both color temp (kelvin) and brightness based on the time of day. I’ve seen the Flux switch component as a solution in the forums, but to me Flux was designed to start at a cool daylight white in the morning and fade down throughout the day. I wanted a true circadian rhythm, start dim and warm in the morning and work its way up to cool and bright by noon, then back to dim, and warm come night time. in Update 0.48 the “light.lifx_set_state” was added which prompted me to finally attempt to write my code.
What I got was a highly customizable and scalable code!
Side Note: “input_boolean.scene_mode” allows me to pause the update process so I can run other scenes uninterrupted.
Huge shout out to CCOSTAN who has also been a great influence to me and my home automation. He had a similar code which ended up being the backbone to what you see below! Check out his GitHub for yourself!
alias: 'Light Adjustment'
- platform: time
# Matches every hour on the hour
minutes: 00
seconds: 15
- platform: state
entity_id: input_boolean.alert_mode
to: "off"
- platform: state
entity_id: input_boolean.scene_mode
to: "off"
- platform: homeassistant
event: start
condition:
- condition: state
state: 'off'
- condition: state
state: 'off'
- service: light.lifx_set_state
entity_id: group.bathroom_lights, group.bedroom_lights
data_template:
color_temp: >
{% set hour=states("sensor.time").split(':')[0] | int %}
{%- if hour >= 0 and hour < 1 -%}
365
{%- elif hour >= 1 and hour < 2 -%}
365
{%- elif hour >= 2 and hour < 3 -%}
365
{%- elif hour >= 3 and hour < 4 -%}
365
{%- elif hour >= 4 and hour < 5 -%}
360
{%- elif hour >= 5 and hour < 6 -%}
330
{%- elif hour >= 6 and hour < 7 -%}
310
{%- elif hour >= 7 and hour < 8 -%}
285
{%- elif hour >= 8 and hour < 9 -%}
250
{%- elif hour >= 9 and hour < 10 -%}
220
{%- elif hour >= 10 and hour < 11 -%}
180
{%- elif hour >= 11 and hour < 12 -%}
165
{%- elif hour >= 12 and hour < 13 -%}
155
{%- elif hour >= 13 and hour < 14 -%}
165
{%- elif hour >= 14 and hour < 15 -%}
180
{%- elif hour >= 15 and hour < 16 -%}
220
{%- elif hour >= 16 and hour < 17 -%}
250
{%- elif hour >= 17 and hour < 18 -%}
285
{%- elif hour >= 18 and hour < 19 -%}
310
{%- elif hour >= 19 and hour < 20 -%}
330
{%- elif hour >= 20 and hour < 21 -%}
360
{%- elif hour >= 21 and hour < 22 -%}
365
{%- elif hour >= 22 and hour < 23 -%}
365
{%- elif hour >= 23 and hour < 24 -%}
365
{%- endif %}
brightness: >
5
5
5
30
55
80
105
130
155
180
205
230
255
230
205
180
155
130
105
80
55
30
5
5
{%- endif %}
transition: 3
**This post was filled with more links, however since I’m a “new user” I’m not allowed to make my posts more informational…
