Hi everyone… Thanks for the help in advance.
As stated, the LIFX component is not loading since the latest rounds of upgrades. I have tried rolling back to 0.37 to only find that it still fails to load.
It seems that there have been a couple of other threads that had the same problem with no resolution.
System: RPI3 w/RJLite
HASetup: All in one installer
Specific Config:
light: - platform: lifx allow_unreachable: true
Log:
17-03-22 12:20:51 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform lifx Traceback (most recent call last): File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 153, in _async_setup_platform entity_platform.schedule_add_entities, discovery_info File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__ yield self # This tells Task to wait for completion. File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup value = future.result() File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result raise self._exception File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run result = self.fn(*self.args, **self.kwargs) File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/light/lifx.py", line 52, in setup_platform lifx_library = LIFX(add_devices, server_addr, broadcast_addr) File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/light/lifx.py", line 74, in __init__ broadcast_addr) File "/home/homeassistant/.homeassistant/deps/liffylights.py", line 100, in __init__ self._sock.bind((listener_addr, UDP_PORT)) OSError: [Errno 98] Address already in use
I should also note that the following config doesn’t work:
light: - platform: lifx broadcast: 192.168.1.255 allow_unreachable: true
Anyone have any insight that could possibly help?
Thanks again!
