LIFX HomeKit Controller trigger to enable dimming
Hi, the HomeKit Controller integration allows an automation to be triggered by the LIFX switch using a Single, Double or Long press of a button. Typically the single-press trigger is used to with a toggle action to turn a light on or off.
I would like an additional trigger for each of the buttons that fires when the Long period starts, that is, at the time when releasing the button would generate a Long-press trigger. This trigger would allow the automation to continuously raise (or lower) a globes brightness while the button is held down.
Note that this type of trigger is available with the Ikea TRADFRI switch integration.
