Hey all, I’m still really new to home assistant and I’m hoping someone can help me figure out why Lifx and nest can’t seem to be detected. My system monitor also refuses to work. I’ve check the homeassistant.log file, but there’s nothing in there (literally empty). Here is my configuration.yaml:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: !lat
longitude: !long
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: !elevation
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/New_York
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
http:
# Uncomment this to add a password (recommended!)
# api_password: PASSWORD
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather Prediction
- platform: yr
- platform: systemmonitor
resources:
- type: disk_use_percent
arg: /home
- type: memory_free
- type: processor_use
light:
platform: lifx
server: 192.168.1.119
broadcast: 192.168.1.255
nest:
username: !nest_user
password: !nest_pass
climate:
platform: nest
device_tracker:
- platform: ddwrt
host: 192.168.1.1
username: !ddwrt_user
password: !ddwrt_pass
logger:
default: info
Everything else seems to be working fine, it can access my router and display connected devices, it discovers my chromecasts and even my plex server is auto-discovered. It just can’t access my Lifx and Nest devices. Instead, when I navigate to the webpage, I see this card:
I’ve tried the Lifx with and without the server and broadcast attributes defined, so not sure where to go from there. Is there any additional configuration I need to do?
