LIFX not working after upgrade to 0.37
After upgrading to 0.37, the LIFX platform fails to load with the following added to the log file:
17-01-29 15:36:29 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform lifx
  File "C:\Users\Ryan\AppData\Local\Programs\Python\Python35\lib\site-packages\homeassistant\helpers\entity_component.py", line 151, in _async_setup_platform
    entity_platform.add_entities, discovery_info
  File "C:\Users\Ryan\AppData\Local\Programs\Python\Python35\lib\asyncio\futures.py", line 361, in __iter__
    yield self  # This tells Task to wait for completion.
  File "C:\Users\Ryan\AppData\Local\Programs\Python\Python35\lib\asyncio\tasks.py", line 296, in _wakeup
    future.result()
  File "C:\Users\Ryan\AppData\Local\Programs\Python\Python35\lib\asyncio\futures.py", line 274, in result
    raise self._exception
  File "C:\Users\Ryan\AppData\Local\Programs\Python\Python35\lib\concurrent\futures\thread.py", line 55, in run
  File "C:\Users\Ryan\AppData\Local\Programs\Python\Python35\lib\site-packages\homeassistant\components\light\lifx.py", line 50, in setup_platform
    lifx_library = LIFX(add_devices, server_addr, broadcast_addr)
  File "C:\Users\Ryan\AppData\Local\Programs\Python\Python35\lib\site-packages\homeassistant\components\light\lifx.py", line 72, in __init__
    broadcast_addr)
  File "C:\Users\Ryan\AppData\Roaming\.homeassistant\deps\liffylights.py", line 100, in __init__
    self._sock.bind((listener_addr, UDP_PORT))
OSError: [WinError 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted
Here is the configuration:
light:
  platform: lifx
  broadcast: 192.168.2.255
These lights were working prior to the update. Any suggestions?
My lifx lights are working ok after the update.
I have also this line in my config:
allow_unreachable: true
Rule #1: Always reboot first.
I rebooted the pc and all is well. I went ahead and added the allow_unreachable line to my code as well. Thanks!
