LIFX Problems out of the blue
suddenly all the LIFX cloud api died and scenes become unavailable
same config
scene:
  - platform: lifx_cloud
    token: HIDDEN
on 104.3 stable
worked yesterday on same build
reboot/restarted multiple time
following error each time
curl works. also http request = 200 (ok)
  File "/usr/src/homeassistant/homeassistant/components/lifx_cloud/scene.py", line 41, in async_setup_platform
    scenes_resp = await httpsession.get(url, headers=headers)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 483, in _request
    timeout=real_timeout
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 523, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 859, in _create_connection
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 986, in _create_direct_connection
    req=req, client_error=client_error)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 936, in _wrap_create_connection
    return await self._loop.create_connection(*args, **kwargs)  # type: ignore  # noqa
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 985, in create_connection
    ssl_handshake_timeout=ssl_handshake_timeout)
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 1013, in _create_connection_transport
    await waiter
concurrent.futures._base.CancelledError
  File "/usr/local/lib/python3.7/site-packages/async_timeout/__init__.py", line 45, in __exit__
    self._do_exit(exc_type)
  File "/usr/local/lib/python3.7/site-packages/async_timeout/__init__.py", line 92, in _do_exit
    raise asyncio.TimeoutError
concurrent.futures._base.TimeoutError
all of my scenes have just disappeared too
