Hello. I am relatively new to Home Assistant. I have LIFX bulbs and I have been setting them up within Home Assistant. Also as a test, I have been using the HK driver for the LIFX bulbs just to see what the difference in the behavior is. I know that with HK its push notifications vs LIFX driver polling and the fact you get the “fancy” LIFX features with its driver. However I have a Lighting Group of the LIFX bulbs using the HK driver and a Lighting Group of the LIFX bulbs using the LIFX driver. I am noticing differences in the behavior of the bulb like when I write a script to set the LIFX group using the LIFX driver to set the group to 3500k, it works as I would expect. When I write a script to set the LIFX group using the HK drive to set the group to 3500k, the light appears very yellow and different than how I would expect.
Can anyone help me figure out why there is a difference in behavior in case this is a bug?
Thank you in advance!
