Hi
is this configuration under action correct? it will not work but the test show no errors.
Only the light go on if its off. if its on nothing happens.
Has anyone may a alternative config?
thanks
- alias: Wohnzimmer_Licht_Tag
initial_state: 'on'
- platform: state
entity_id: timer.wohnzimmer_licht_timer
to: 'active'
condition:
condition: and
conditions:
- condition: sun
after: sunrise
after_offset: "0:15:00"
- condition: time
before: '23:15:00'
- service: light.turn_on
data_template:
entity_id: light.wohnraum_und_essbereich
brightness: >-
{% if is_state('light.wohnraum_und_essbereich', 'on') %}
254
{% else %}
254
{% endif %}
kelvin: >-
{% if is_state('light.wohnraum_und_essbereich', 'off') %}
2700
{% endif %}
transition: >-
1
{% else %}
3
{% endif %}
123
(Taras)
November 15, 2019, 4:31pm
2
You say it doesn’t work … and then you explain how it’s working.
So it does work, just not the way you want it. Please explain what you want it to do.
the room has 2 motion sensors and if I change the color via app the motionsensor change the color and brightness to default. it should be manual change.
Why don’t you take the motion sensor as a trigger and add a condition to only turn the light on if it is not already on?
123
(Taras)
November 15, 2019, 5:04pm
5
Sorry, I do not understand your explanation. Your automation contains references to sunrise and time yet your explanation contains no reference to any of that.
yes motionsensors are trigger in a other automation.
Based on timer the motion sensor starts a timer and if the timer is active it trigger this automation and differentiate inside the conditions for the specified brightness and color.
Sorry, I also don’t understand what you want to do.
Like this?
Motion detected
condition:
only do this between 15 min after sunrise until 23:15
if light is on -> do nothing
if light is off -> turn it on
tom_l
November 15, 2019, 5:18pm
8
For a start, this template has the same output regardless of the test result:
brightness: >-
254
{% else %}
254
{% endif %}
So can be replaced with:
brightness: 254
And this will generate an error if the state is ‘on’ as there is no else case to provide a kelvin value:
kelvin: >-
2700
{% endif %}
oh you are right! I thought the there is no else part required
thanks
123
(Taras)
November 15, 2019, 6:42pm
11
Your templates appear to set values only if the light is currently off
and to leave the values unchanged if the light is already on
. You can simplify your templates by adding a condition that the light must be off
condition:
condition: and
conditions:
- condition: sun
after: sunrise
- condition: time
before: '23:15:00'
- condition: state
state: 'off'
data_template:
brightness: 254
kelvin: 2700
transition: 1
yes that’s a good idea but there is one more automation which dimm the light. so this rule should start the previous state maybe.
I can post my full light automation if you want.
Please post you full automation. Maybe we’ll understand better.
- alias: Wohnzimmer_isDark
initial_state: 'on'
- platform: state
entity_id: sensor.wohnzimmer_bewegungsmelder_1_3
- platform: state
entity_id: input_number.wohnzimmer_lux_slider
- platform: homeassistant
event: start
condition:
- condition: state
state: 'off'
- condition: template
value_template: '{{ states.sensor.wohnzimmer_bewegungsmelder_1_3.last_changed >= states.input_datetime.wohnzimmer_last_off.last_changed }}'
- service: variable.set_variable
variable: wohnzimmer_night
value_template: >-
{% if states("sensor.wohnzimmer_bewegungsmelder_1_3") | float < states("input_number.wohnzimmer_lux_slider") | float %}
True
{% else %}
False
{% endif %}
- alias: Wohnzimmer_NoMotion
initial_state: 'on'
- platform: state
entity_id: binary_sensor.wohnzimmer_bewegungsmelder_1
to: 'off'
- service: input_datetime.set_datetime
data_template:
entity_id: input_datetime.wohnzimmer_last_off
datetime: "{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"
- alias: Wohnzimmer_Motion
initial_state: 'on'
- platform: state
to: 'off'
event: start
data_template:
entity_id: input_datetime.wohnzimmer_last_on
- alias: Wohnzimmer_Licht_above_45Lux
initial_state: 'on'
- platform: numeric_state
above: 45
condition:
condition: and
conditions:
- condition: state
state: 'on'
- condition: sun
after: sunrise
after_offset: "03:00:00"
- service: light.turn_off
value: False
- alias: Wohnzimmer_Bewegung_erkannt
initial_state: 'on'
- platform: state
to: 'on'
- platform: state
entity_id: binary_sensor.wohnzimmer_bewegungsmelder_2
to: 'on'
condition:
- condition: state
entity_id: variable.wohnzimmer_night
state: 'True'
#problem wenn nach den dimmen das ausgefüht wird
- service: timer.cancel
entity_id:
- timer.wohnzimmer_licht_timer
- timer.wohnzimmer_licht_dim_timer
- timer.wohnzimmer_licht_taster_shortpress_timer
- timer.wohnzimmer_licht_taster_longpress_timer
- service: timer.start
- alias: Wohnzimmer_Timer_Ende
initial_state: 'on'
- platform: event
event_type: timer.finished
event_data:
condition:
condition: and
conditions:
- condition: state
state: 'on'
- condition: state
entity_id: group.wohnbereich_motionsensor
state: 'off'
- service: homeassistant.turn_on
data_template:
brightness: '{{ ((float(states.light.wohnraum_und_essbereich.attributes.brightness)) / 2) | int}}'
transition: 5
entity_id: timer.wohnzimmer_licht_dim_timer
- alias: Wohnzimmer_Timer_Ende_2
initial_state: 'on'
- platform: event
event_data:
condition:
condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'on'
- alias: Wohnzimmer_Timer_Dim_Ende
initial_state: 'on'
- platform: event
event_data:
condition:
- condition: state
state: 'on'
- service: homeassistant.turn_off
entity_id:
- light.wohnraum_und_essbereich
# Lichteinstellungen
- alias: Wohnzimmer_Licht_Morgen
initial_state: 'on'
- platform: state
to: 'active'
condition:
condition: and
conditions:
- condition: time
after: '05:00:00'
- condition: sun
before: sunrise
before_offset: "0:15:00"
entity_id:
kelvin: 2700
brightness_pct: 100
transition: 4
initial_state: 'on'
- platform: state
to: 'active'
condition:
condition: and
conditions:
- condition: sun
after: sunrise
- condition: time
before: '23:15:00'
data_template:
brightness: >-
254
{% else %}
254
{% endif %}
color_temp: >-
370
{% else %}
370
{% endif %}
transition: >-
3
{% else %}
1
{% endif %}
- alias: Wohnzimmer_Licht_Nacht
initial_state: 'on'
- platform: state
to: 'active'
condition:
condition: or
conditions:
- condition: time
after: '23:15:00'
before: '23:59:59'
- condition: time
after: '00:00:00'
before: '05:00:00'
entity_id:
kelvin: 2700
brightness_pct: 65
transition: 4
123
(Taras)
November 21, 2019, 3:19pm
15
What is the reason for doing this?
brightness: >-
254
{% else %}
254
{% endif %}
It is equivalent to this:
brightness: 254
that’s the preparation for later to restore the old/current value
Mutt
(Muttley)
November 21, 2019, 3:57pm
17
You can’t retrieve anything from that.
Start again, what is it you are trying to do ?
the problem is solved. I only post the complete automation.
123
(Taras)
November 21, 2019, 5:19pm
19
Well, not truly complete because you just explained to me:
In its current form, the example contains templates that, hopefully, no one will copy verbatim.
tom_l
November 22, 2019, 12:05am
20
Also this:
value_template: >-
True
{% else %}
False
{% endif %}
Can be simplified to:
value_template: >-
{{ states("sensor.wohnzimmer_bewegungsmelder_1_3")|float < states("input_number.wohnzimmer_lux_slider")|float }}
As the comparison will return True/False.
tom_l
November 22, 2019, 12:07am
21
I believe Steve means it is a place-holder for future code to be entered to retrieve a previous state.
