Light addressable set command
I made a simple fire alarm device with two analog sensors, one buzzer and 4pcs WS2811 led. Goal is when alarm goes on it activate buzzer and LED’s start to pulse in red color. That work ok :grinning:
But when alarm goes off, buzzer is deactivated but LED’s are also off :frowning:
Goal is that 2 LED’s light in green color (preferably at 30%).
Here is part of code:
  - platform: adc
    pin: 3
    attenuation: 11db
    update_interval: 5s
    on_value_range:
      - below: 1.4
        then:
          - switch.turn_on: buzz
          - light.turn_off: kitchen_alarm_light
          - light.turn_on:
              brightness: 100%
              red: 100%
              green: 75%
              blue: 0
              effect: Fast Pulse
      - above: 2.0
        then:
          - switch.turn_off: buzz
          - light.addressable_set:
                range_from: 0
                range_to: 4
                red: 0%
                green:  0%
                blue: 0%
          - delay: 100ms
                range_from: 0
                range_to: 2
                red: 13.3%
                green:  54.5%
                blue: 13.3%
